chirpa
Mar 07, 2009Luminary
Running VirtualBox VM host on ReadyNAS Pro
What is VirtualBox? So, I got bored while laundry was going... and decided to see how well a virtual OS would run on the Pro. My first choice of VM was VirtualBox, just cause I'm familiar with it a...
Lichon
May 22, 2010Aspirant
Tried on a new Pro with 4.2.9 (before my upgrade to Ext4). Not sure if your steps would work on a 4.2.9 Ext4 system.
viewtopic.php?p=231780#p231780
What risk there to use the compile method ?
