chirpa
Mar 07, 2009Luminary
Running VirtualBox VM host on ReadyNAS Pro
What is VirtualBox? So, I got bored while laundry was going... and decided to see how well a virtual OS would run on the Pro. My first choice of VM was VirtualBox, just cause I'm familiar with it a...
WhoCares_
Jun 04, 2010Mentor
You're right, libcrypt.so seems to be missing from 4.2.11 whereas it was part of 4.2.9. You can get it by doing:
This will install some other stuff on the ReadyNAS like the gcc compiler and such but since you're already compiling the VBox drivers I guess most of it should be there already.
What makes me wonder though is that your system reports libc6-dev as being installed. It wasn't on my system and installed just fine using the commands above.
Maybe you could try to remove libc6-dev using "apt-get remove libc6.dev" and re-installing it? As an alternative you could try to
-Stefan
apt-get update
apt-get install libc6-dev
apt-get install aptitude
aptitude download libc6-dev
dpkg -i libc6-dev_2.7-18lenny2_i386.deb
-Stefan
