chirpa
Mar 07, 2009Luminary
Running VirtualBox VM host on ReadyNAS Pro
What is VirtualBox? So, I got bored while laundry was going... and decided to see how well a virtual OS would run on the Pro. My first choice of VM was VirtualBox, just cause I'm familiar with it a...
berkut1
Jun 04, 2010Tutor
WhoCares? wrote: You're right, libcrypt.so seems to be missing from 4.2.11 whereas it was part of 4.2.9. You can get it by doing: apt-get update
apt-get install libc6-dev
Hmm, could this be a problem with the GPL for 4.2.11?
nas3:/backup/CDs# apt-get update
Ign http://www.readynas.com 4.2.10/ Release.gpg
Get:1 http://ftp.debian.org etch Release.gpg [1033B]
Ign http://www.readynas.com 4.2.10/ Packages/DiffIndex
Hit http://ftp.debian.org etch Release
Hit http://www.readynas.com 4.2.10/ Packages
Ign http://ftp.debian.org etch/main Packages/DiffIndex
Hit http://ftp.debian.org etch/main Packages
Fetched 1B in 1s (1B/s)
Reading package lists... Done
It is listing release/packages for 4.2.10 instead of 4.2.11.
WhoCares? wrote: Maybe you could try to remove libc6-dev using "apt-get remove libc6.dev" and re-installing it? As an alternative you could try to apt-get install aptitude
aptitude download libc6-dev
dpkg -i libc6-dev_2.7-18lenny2_i386.deb[/code
Unfortunately this suggestion did not work as well. I am also getting warnings about these packages cannot be authenticated. Is this a problem?
At this point would it be a good idea to do a factory reinstall and start afresh? In my naive efforts I may have missed some other important points. The system I'm working on is a new Pro which was upgraded to 4.2.11 with no add-ons installed. I've read the forum the as carefully as I could and used Mackila's instructions up to the point of running VboxManage which is were I've run into the missing libc6 problem.
