chirpa
Mar 07, 2009Luminary
Running VirtualBox VM host on ReadyNAS Pro
What is VirtualBox? So, I got bored while laundry was going... and decided to see how well a virtual OS would run on the Pro. My first choice of VM was VirtualBox, just cause I'm familiar with it a...
berkut1
Jun 04, 2010Tutor
chirpa wrote: Try editing your /etc/apt/sources.list, and change references for 4.2.10 to 4.2.11.
Your suggested change resulted in:
nas3:~# apt-get update
Get:1 http://ftp.debian.org etch Release.gpg [1033B]
Get:2 http://ftp.debian.org etch Release [67.8kB]
Get:3 http://ftp.debian.org etch/main Packages [5477kB]
Ign http://www.readynas.com 4.2.11/ Release.gpg
Get:4 http://www.readynas.com 4.2.11/ Packages [5783B]
Fetched 5552kB in 34s (160kB/s)
Reading package lists... Done
I then performed the following on a newly built drive:
apt-get install build-essential
apt-get install bzip2
apt-get install lmza
cd /c/backup
wget http://www.readynas.com/download/GPL/RNDP6xxx_4.2.11_WW_src.zip
unzip -q RNDP6xxx_4.2.11_WW_src.zip -d ./GPL
cd GPL/linux-2.6.33.4/
make clean
make oldconfig
make all
ln -s /c/backup/GPL/linux-2.6.33.4/ /usr/src/linux
KERN_DIR=/usr/src/linux
cd /c/backup
mkdir virtualbox
cd virtualbox
wget http://download.virtualbox.org/virtualbox/3.2.2/VirtualBox-3.2.2-62298-Linux_amd64.run
chmod 755 VirtualBox-3.2.2-62298-Linux_amd64.run
./VirtualBox-3.2.2-62298-Linux_amd64.run
apt-get install lib64stdc++6
apt-get install lib64z1
cd /c/backup
mkdir CDs
cd CDs
# copied target OS image here
# Test the Virtualbox
VBoxManage list hostinfo
Execution of the VBoxManage line still resulted in
/opt/VirtualBox/VBoxManage: error while loading shared libraries: libcrypt.so.1: cannot open shared object file: No such file or directory
If I again attempt to load the apparently missing library I get
# apt-get install libc6-dev
Building dependency tree... Done
libc6-dev is already the newest version.
0 upgraded, 0 newly installed, 0 to remove and 43 not upgraded.
At this point I'm not sure what I am doing wrong in the install - as it appears everything needed is in place.
