chirpa
Mar 07, 2009Luminary
Running VirtualBox VM host on ReadyNAS Pro
What is VirtualBox? So, I got bored while laundry was going... and decided to see how well a virtual OS would run on the Pro. My first choice of VM was VirtualBox, just cause I'm familiar with it a...
chirpa
Jun 04, 2010Luminary
Try this:
The 32-bit libcrypt.so is in the root image, but not the 64-bit one.
# apt-get --reinstall install libc6-amd64
