chirpa
Mar 07, 2009Luminary
Running VirtualBox VM host on ReadyNAS Pro
What is VirtualBox? So, I got bored while laundry was going... and decided to see how well a virtual OS would run on the Pro. My first choice of VM was VirtualBox, just cause I'm familiar with it a...
berkut1
Jun 04, 2010Tutor
FYI
For those of you wishing to install Windows 2K/NT/XP it appears that the Windows Intel SATA driver "F32.IMA" is no longer available from Intel as referenced in chirpa's Virtualbox WinXP SATA install link Windows SATA Support. Nor could I find it anywhere on the web. The work around to creating a floppy image of the SATA drivers is described in How to install Windows 2000/XP/2003 guests with SATA support
To create the image on the Pro I needed mtools:
I then copied the zip file from the Option 3b - unofficial drivers location and put them into my working floppy directory.
From there I followed the recipe to make the floppy image.
Once I had the floppy image I was able to complete the creation of my WinXP guest OS VM described in the Windows SATA Support page.
apt-get install mtools
mkdir floppy
cd floppy
# copy the XP AHCI v7.0.0.1020 for ICH8 Driver zip to the target folder
cp <source-path> .
unzip AHCI_v7.0.0.1020_for_ICH8.zip
dd if=/dev/zero of=./ich8.img bs=1k count=1440
mformat -i ich8.img -f 1440 ::
mcopy -i ich8.img "AHCI v7.0.0.1020 for ICH8"/* ::
