chirpa
Mar 07, 2009Luminary
Running VirtualBox VM host on ReadyNAS Pro
What is VirtualBox? So, I got bored while laundry was going... and decided to see how well a virtual OS would run on the Pro. My first choice of VM was VirtualBox, just cause I'm familiar with it a...
berkut1
Jun 07, 2010Tutor
ahpsi wrote: Is this the file you are looking for -> http://wiki.inisec.com/index.php/File:F32.IMA?
Thanks for finding it. This will help out those who wish to skip the steps I had to go through to build a SATA driver floppy image.
