chirpa
Mar 07, 2009Luminary
Running VirtualBox VM host on ReadyNAS Pro
What is VirtualBox? So, I got bored while laundry was going... and decided to see how well a virtual OS would run on the Pro. My first choice of VM was VirtualBox, just cause I'm familiar with it a...
berkut1
Jun 11, 2010Tutor
I've successfully have Windows XP running on my virutalbox v3.2.4. I've been successful in updating windows with all of the current security patches except for KB958869. This patches fixes a security hole with their GDI+ library. So the question I have is has anyone else had problems installing this patch on their WinXP guest? And if so where you able to resolve it?
Thanks
Thanks
