chirpa
Mar 07, 2009Luminary
Running VirtualBox VM host on ReadyNAS Pro
What is VirtualBox? So, I got bored while laundry was going... and decided to see how well a virtual OS would run on the Pro. My first choice of VM was VirtualBox, just cause I'm familiar with it a...
berkut1
Jun 20, 2010Tutor
chirpa,
I too tried that but it was not successful...
currently it does not launch the VirtualboxHeadless process upon startup
I inserted the virtualbox line into /etc/default/services just before the WAK_ON_LAN line
And then added the following line to /etc/frontview/addons/addons.conf
And finally added your vboxctrl.sh script to my /root directory.
and used chmod 755 to make it executable.
I also verified that the
System Config:
ReadyNAS Pro w/ 4GB
Firmware 4.2.11
Virtualbox version 3.2.4
USER_HOME_DIRECTORY_RECYCLE_MAX_DAYS=10
USER_HOME_DIRECTORY_RECYCLE_MAX_SIZE=2048
VIRTUALBOX=1
WAKE_ON_LAN=0
VIRTUALBOX!!VirtualBox!!3.2.4!!/root/vboxctrl.sh start!!/root/vboxctrl.sh stop
#! /bin/sh
# Control VirtualBox with system startup/shutdown
PATH=/bin:/usr/bin
case "$1" in
start|"")
/usr/bin/VBoxHeadless --startvm "WinXP" --vrdpport 8888 --vrdp on &
stop)
/usr/bin/VBoxManage controlvm "WinXP" savestate
status)
/usr/bin/VBoxManage showvminfo "WinXP" | grep '^State:'
restart|reload|force-reload)
echo "Error: argument '$1' not supported" >&2
exit 3
echo "Usage: vboxctrl.sh [start|stop|status]" >&2
exit 3
esac
successfully launched the Vbox when executed from the command line.
vboxctrl.sh start
System Config:
ReadyNAS Pro w/ 4GB
Firmware 4.2.11
