chirpa
Mar 07, 2009Luminary
Running VirtualBox VM host on ReadyNAS Pro
What is VirtualBox? So, I got bored while laundry was going... and decided to see how well a virtual OS would run on the Pro. My first choice of VM was VirtualBox, just cause I'm familiar with it a...
WhoCares_
Jun 20, 2010Mentor
I'm not sure but I think the start/stop scripts are run under the account of the admin user. So I believe you should move the vboxctrl.sh to another location like /etc/init.d or /etc/myscripts, check for proper file and directory permissions then adapt the addons.conf and give it another try.
-Stefan
-Stefan
