chirpa
Mar 07, 2009Luminary
Running VirtualBox VM host on ReadyNAS Pro
What is VirtualBox? So, I got bored while laundry was going... and decided to see how well a virtual OS would run on the Pro. My first choice of VM was VirtualBox, just cause I'm familiar with it a...
horim80
Aug 13, 2010Guide
Hi,
help me~
I've follow below steps..
http://www.readynas.com/forum/viewtopic.php?p=231809#p231809
how can I fix it?
help me~
ReadyNAS-PRO:/# uname -r
2.6.33.6.RNx86_64.2.1
ReadyNAS-PRO:/usr/bin# /etc/init.d/vboxdrv start
Starting VirtualBox kernel module ...failed!
(modprobe vboxdrv failed. Please use 'dmesg' to find out why)
ReadyNAS-PRO:/# vboxwebsrv
WARNING: The vboxdrv kernel module is not loaded. Either there is no module
available for the current kernel (2.6.33.6.RNx86_64.2.1) or it failed to
load. Please recompile the kernel module and install it by
sudo /etc/init.d/vboxdrv setup
You will not be able to start VMs until this problem is fixed.
/opt/VirtualBox/vboxwebsrv: error while loading shared libraries: libcrypt.so.1: cannot open shared object file: No such file or directory
ReadyNAS-PRO:/# /etc/init.d/vboxdrv setup
Stopping VirtualBox kernel module ...done.
Removing old VirtualBox netadp kernel module ...done.
Removing old VirtualBox netflt kernel module ...done.
Removing old VirtualBox kernel module ...done.
Recompiling VirtualBox kernel module ...done.
how can I fix it?
