chirpa
Mar 07, 2009Luminary
Running VirtualBox VM host on ReadyNAS Pro
What is VirtualBox? So, I got bored while laundry was going... and decided to see how well a virtual OS would run on the Pro. My first choice of VM was VirtualBox, just cause I'm familiar with it a...
horim80
Aug 13, 2010Guide
WhoCares? wrote: Horim,
Have you seen this:
chirpa wrote: Try this: # apt-get --reinstall install libc6-amd64
The 32-bit libcrypt.so is in the root image, but not the 64-bit one.
Also, the output of dmesg would be helpful.
-Stefan
ReadyNAS-PRO:/# apt-get --reinstall install libc6-amd64
Reading package lists... Done
Building dependency tree... Done
0 upgraded, 0 newly installed, 1 reinstalled, 0 to remove and 41 not upgraded.
Need to get 4192kB of archives.
After unpacking 0B of additional disk space will be used.
Do you want to continue [Y/n]? y
WARNING: The following packages cannot be authenticated!
libc6-amd64
Install these packages without verification [y/N]? y
Get:1 http://www.readynas.com 4.2.13/ libc6-amd64 2.7-18lenny2 [4192kB]
Fetched 4192kB in 5s (767kB/s)
debconf: delaying package configuration, since apt-utils is not installed
(Reading database ... 21978 files and directories currently installed.)
Preparing to replace libc6-amd64 2.7-18lenny2 (using .../libc6-amd64_2.7-18lenny2_i386.deb) ...
Unpacking replacement libc6-amd64 ...
Setting up libc6-amd64 (2.7-18lenny2) ...
ReadyNAS-PRO:/# /etc/init.d/vboxdrv start
Starting VirtualBox kernel module ...failed!
(modprobe vboxdrv failed. Please use 'dmesg' to find out why)
ReadyNAS-PRO:/# vboxwebsrv
WARNING: The vboxdrv kernel module is not loaded. Either there is no module
available for the current kernel (2.6.33.6.RNx86_64.2.1) or it failed to
load. Please recompile the kernel module and install it by
sudo /etc/init.d/vboxdrv setup
You will not be able to start VMs until this problem is fixed.
Oracle VM VirtualBox web service version 3.2.8
(C) 2005-2010 Oracle Corporation
All rights reserved.
2010-08-14 13:59:06 [ P ] Socket connection successful: host = default (localhost), port = 18083, master socket = 10
^C
ReadyNAS-PRO:/#
ReadyNAS-PRO:/# /etc/init.d/vboxdrv setup
Stopping VirtualBox kernel module ...done.
Removing old VirtualBox netadp kernel module ...done.
Removing old VirtualBox netflt kernel module ...done.
Removing old VirtualBox kernel module ...done.
Recompiling VirtualBox kernel module ...failed!
(Look at /var/log/vbox-install.log to find out what went wrong)
it's not helped.. could you give me more advice..
