chirpa
Mar 07, 2009Luminary
Running VirtualBox VM host on ReadyNAS Pro
What is VirtualBox? So, I got bored while laundry was going... and decided to see how well a virtual OS would run on the Pro. My first choice of VM was VirtualBox, just cause I'm familiar with it a...
horim80
Aug 14, 2010Guide
chirpa wrote: Output of /var/log/vbox-install.log ?
ReadyNAS-PRO:/# cat /var/log/vbox-install.log
Makefile:162: Warning: using /usr/src/linux as the source directory of your Linux kernel. If this is not correct, specify KERN_DIR=<directory> and run Make again.
Makefile:170: *** Error: /usr/src/linux (version 2.6.30.9.RNx86_64.2.2) does not match the current kernel (version 2.6.33.6.RNx86_64.2.1).
