chirpa
Mar 07, 2009Luminary
Running VirtualBox VM host on ReadyNAS Pro
What is VirtualBox? So, I got bored while laundry was going... and decided to see how well a virtual OS would run on the Pro. My first choice of VM was VirtualBox, just cause I'm familiar with it a...
WhoCares_
Aug 14, 2010Mentor
You need to create a virtual harddrive and also connect it to the virtual machine. -> http://www.virtualbox.org/manual/ch08.h ... ge-storage & http://www.virtualbox.org/manual/ch08.h ... -createvdi
-Stefan
-Stefan
