chirpa
Mar 07, 2009Luminary
Running VirtualBox VM host on ReadyNAS Pro
What is VirtualBox? So, I got bored while laundry was going... and decided to see how well a virtual OS would run on the Pro. My first choice of VM was VirtualBox, just cause I'm familiar with it a...
alouch47
Sep 16, 2010Guide
muggsy wrote:
I think the version of Virtualbox on apt might be older than using the link from virtualbox.org
Apt-get install version 3.2.8 which is according to the VB site, the latest.
I'll try get the deb package from the site, & I'll tell you if it's work this way.
