chirpa
Mar 07, 2009Luminary
Running VirtualBox VM host on ReadyNAS Pro
What is VirtualBox? So, I got bored while laundry was going... and decided to see how well a virtual OS would run on the Pro. My first choice of VM was VirtualBox, just cause I'm familiar with it a...
WhoCares_
Sep 16, 2010Mentor
Neither, you'll have to build from source.
The ReadyNAS firmware is built on etch but with some updated packages from Lenny thrown in. So chances are you won't be able to use any external .deb packages without major modification to the ReadyNAS base system.
-Stefan
-Stefan
