chirpa
Mar 07, 2009Luminary
Running VirtualBox VM host on ReadyNAS Pro
What is VirtualBox? So, I got bored while laundry was going... and decided to see how well a virtual OS would run on the Pro. My first choice of VM was VirtualBox, just cause I'm familiar with it a...
sphardy1
Sep 16, 2010Apprentice
So - I finally got around to reinstalling VB on my Ultra-4.
Here are the steps I used to install the 64 bit version of VB 3.2.8 under RAIDiator 4.2.13 - all worked perfectly first time (though hope I haven't forgotten to copy/paste something)
Hopefully a clean start for those still trying to get this working
cd /c/backup
apt-get update
apt-get install build-essential amd64-libs lib64stdc++6 bzip2 lib64z1 lzma
apt-get --reinstall install libc6-amd64
wget -q http://www.readynas.com/download/GPL/RNDP6xxx_4.2.13_WW_src.zip
unzip -q RNDP6xxx_4.2.13_WW_src.zip -d ./GPL
cd GPL/linux-2.6.33.6
make ARCH=x86_64
make prepare
ln -s /c/backup/GPL/linux-2.6.33.6 /usr/src/linux
export KERN_DIR=/usr/src/linux
wget -q http://download.virtualbox.org/virtualbox/3.2.8/VirtualBox-3.2.8-64453-Linux_amd64.run
chmod 755 VirtualBox-3.2.8-64453-Linux_amd64.run
./VirtualBox-3.2.8-64453-Linux_amd64.run
/etc/init.d/vboxdrv start
