chirpa
Mar 07, 2009Luminary
Running VirtualBox VM host on ReadyNAS Pro
What is VirtualBox? So, I got bored while laundry was going... and decided to see how well a virtual OS would run on the Pro. My first choice of VM was VirtualBox, just cause I'm familiar with it a...
bartw
Sep 22, 2010Aspirant
I would like to throw in a wild question in here ... if the answer is "yes" I'll open a separate topic on it ...
On a Pro, running Virtual Box, running Opensolaris, using ZFS ... would deduplication be supported /working (possibly given enough memory is installed) ?
