chirpa
Mar 07, 2009Luminary
Running VirtualBox VM host on ReadyNAS Pro
What is VirtualBox? So, I got bored while laundry was going... and decided to see how well a virtual OS would run on the Pro. My first choice of VM was VirtualBox, just cause I'm familiar with it a...
WhoCares_
Sep 22, 2010Mentor
Well, the general answer is: Yes, it should. But whether it really works or not you'll have to try for yourself. But since in this scenario OpenSolaris would be the guest machine I see no special benefit in using dedup there.
-Stefan
-Stefan
