chirpa
Mar 07, 2009Luminary
Running VirtualBox VM host on ReadyNAS Pro
What is VirtualBox? So, I got bored while laundry was going... and decided to see how well a virtual OS would run on the Pro. My first choice of VM was VirtualBox, just cause I'm familiar with it a...
sphardy1
Oct 12, 2010Apprentice
Just updated to 3.2.10 on my Ultra-4 - update went fine.
I have seen the following issue - so hopefully solved in this release as the change log claims:
Also noticed there is a new startup script included for vboxwebsrv (/etc/init.d/vboxweb-service) To get it to work however, needed to define the user vboxdrv runs as in /etc/vbox/vbox.cfg - just add the line:
VBoxHeadless: fixed event queue processing problems which led to hangs if the VM could not be started successfully
VBOXWEB_USER='root'
