chirpa
Mar 07, 2009Luminary
Running VirtualBox VM host on ReadyNAS Pro
What is VirtualBox? So, I got bored while laundry was going... and decided to see how well a virtual OS would run on the Pro. My first choice of VM was VirtualBox, just cause I'm familiar with it a...
horim80
Jan 06, 2011Guide
Hi, all
I have installed the VB 4.0.0 on Pro6. (RAIDiator 4.2.15)
Then finished the few jobs by VBoxManage.
But I can't access the VM via MS remote desktop client.
What things should I check for resolve this problem?
Any advice will be appreciated.
Thanks.
VBoxManage createvm --name "WinXP" --ostype "WindowsXP" --register --basefolder /c/backup/virtualbox/machines
VBoxManage createhd --filename "/c/backup/virtualbox/virtual_hdd/ WinXP" --size 5000
VBoxManage storagectl WinXP --name "IDE Controller" --add ide
VBoxManage storagectl WinXP --name "SATA Controller" --add sata
VBoxManage storageattach WinXP --storagectl "IDE Controller" --port 0 --device 0 --type dvddrive --medium "/c/backup/WinXP.iso"
VBoxManage storageattach WinXP --storagectl "SATA Controller" --port 0 --device 0 --type hdd --medium "/c/backup/virtualbox/virtual_hdd/ WinXP.vdi"
VBoxManage modifyvm WinXP --memory 512 --nic1 bridged --bridgeadapter1 eth0 --boot1 dvd --boot2 none --boot3 none --boot4 none
VBoxHeadless --startvm WinXP --vrdp on &
Thanks.
