chirpa
Mar 07, 2009Luminary
Running VirtualBox VM host on ReadyNAS Pro
What is VirtualBox? So, I got bored while laundry was going... and decided to see how well a virtual OS would run on the Pro. My first choice of VM was VirtualBox, just cause I'm familiar with it a...
horim80
Jan 06, 2011Guide
alouch47 wrote: hi,
quick reply here.
I think that by default, the Vm rdp port is @8888
so you should try to connect to : ip_of_vm:8888
Keep us posted if it's ok or not
I tried to connect VM use port 8888 but failed..
Any more advice?
