chirpa
Mar 07, 2009Luminary
Running VirtualBox VM host on ReadyNAS Pro
What is VirtualBox? So, I got bored while laundry was going... and decided to see how well a virtual OS would run on the Pro. My first choice of VM was VirtualBox, just cause I'm familiar with it a...
horim80
Jan 09, 2011Guide
alaeth wrote:
horim80 wrote:
alouch47 wrote: hi,
quick reply here.
I think that by default, the Vm rdp port is @8888
so you should try to connect to : ip_of_vm:8888
Keep us posted if it's ok or not
I tried to connect VM use port 8888 but failed..
Any more advice?
I think the default RDP port is 3389. If you have a Windows system, just connect to the NAS IP, not the IP of the VM (although I'm sure that should work too if it's a Windows VM).
For example, I ran:$ VBoxHeadless --startvm "WinXP"
Oracle VM VirtualBox Headless Interface 3.2.8
(C) 2008-2010 Oracle Corporation
All rights reserved.
Listening on port 3389.
and connected with Windows RDP with <readynas ip>
I have reinstalled the VB 3.2.8 then it works perfectly.
In VB 4.0, when I enter the 'VBoxHeadless --startvm' command, "Listening on port 3389" is doesn't appeared.
I guess VB 4.0 is not compatible with RADIator 4.2.15 yet. Specially network adapter..
Thanks.
