chirpa
Mar 07, 2009Luminary
Running VirtualBox VM host on ReadyNAS Pro
What is VirtualBox? So, I got bored while laundry was going... and decided to see how well a virtual OS would run on the Pro. My first choice of VM was VirtualBox, just cause I'm familiar with it a...
jmalmlund
Feb 07, 2011Aspirant
fbmachines wrote: SSH newb question...
Do I have to keep the SSH client open the whole time a VM is running?
When I close putty, my VM closes. Anyway around this?
Thanks.
Edited my start command in the previous post.. you just need to add an '&' to the end of the start command to put the VBox process into the background allowing you to disconnect your ssh session.
