chirpa
Mar 07, 2009Luminary
Running VirtualBox VM host on ReadyNAS Pro
What is VirtualBox? So, I got bored while laundry was going... and decided to see how well a virtual OS would run on the Pro. My first choice of VM was VirtualBox, just cause I'm familiar with it a...
horim80
Feb 08, 2011Guide
jmalmlund wrote: For those who like me update to VirtualBox 4.0.x, remember that Oracle have change how VBox is packaged and distributed (all binaries are now GPLv2 and no longer ships with VRDP support built in).
This is what I did to install and run 4.0.2 (slightly adopted for easier copy and paste of my commands) and remember that if you log in as root (you really shouldn't) you can skip the 'sudo' part of all the listed commands.
apt-get update
apt-get install build-essential amd64-libs lib64stdc++6 bzip2 lib64z1 lzma
apt-get --reinstall install libc6-amd64
wget -q http://www.readynas.com/download/GPL/RNDP6xxx_4.2.15_WW_src.zip
unzip -q RNDP6xxx_4.2.15_WW_src.zip "linux-2.6.33.7/*"
sudo ln -sn `pwd`/linux-2.6.33.7 /usr/src/linux
cd linux-2.6.33.7
make ARCH=x86_64
make prepare
cd ..
wget -q http://download.virtualbox.org/virtualbox/4.0.2/VirtualBox-4.0.2-69518-Linux_amd64.run
wget -q http://download.virtualbox.org/virtualbox/4.0.2/Oracle_VM_VirtualBox_Extension_Pack-4.0.2-69518.vbox-extpack
chmod 755 VirtualBox-4.0.2-69518-Linux_amd64.run
sudo ./VirtualBox-4.0.2-69518-Linux_amd64.run
sudo /usr/bin/VBoxManage extpack install Oracle_VM_VirtualBox_Extension_Pack-4.0.2-69518.vbox-extpack
Note that it's the extpack that contains the RDP module...
I won't repeat instructions on how to do a basic setup of a virtual machine, only the additions/changes needed for VBox 4.0
VBoxManage modifyvm <uuid|name> --vrde on --vrdeaddress <host ip> --vrdeport <port for RDP>
After this all that's needed to start is
VBoxHeadless --startvm <uuid|name> &
Or if you don't want to configure your machines with static ip/ports for RDP use
VBoxHeadless --startvm <uuid|name> --vrde on --vrdeaddress <host ip> --vrdeport <port for RDP> &
Edit: Added an '&' to the start command to put the process in the background and returning you to the prompt, which enables you to logout and disconnect your ssh session.
Thanks for the infomation!!
