chirpa
Mar 07, 2009Luminary
Running VirtualBox VM host on ReadyNAS Pro
What is VirtualBox? So, I got bored while laundry was going... and decided to see how well a virtual OS would run on the Pro. My first choice of VM was VirtualBox, just cause I'm familiar with it a...
leak
Mar 31, 2011Aspirant
Ok, I've got to missed something here. Right now I have successfully installed Virtualbox on my Ultra, but then what?
I want to install CentOS, but how do I do that? Never used VB before. Is there any program I run on my PC that connects and manage VB on my NAS? Where I can install my ISO's, stop, start the server and so on?
And how do I check if VB is running? When i start it it says this
But when I type
I see nothing. What should I do :) ?
edit; my bad.
t0wnz:/backup/GPL# /etc/init.d/vboxdrv start
Starting VirtualBox kernel module ...done.
t0wnz:/backup/GPL#
But when I type
t0wnz:/backup/GPL# ps | grep vboxdrv
t0wnz:/backup/GPL#
edit; my bad.
t0wnz:/backup/GPL# ps -ef | grep vboxdrv
root 12170 20742 0 14:33 pts/0 00:00:00 grep vboxdrv
t0wnz:/backup/GPL#
