chirpa
Mar 07, 2009Luminary
Running VirtualBox VM host on ReadyNAS Pro
What is VirtualBox? So, I got bored while laundry was going... and decided to see how well a virtual OS would run on the Pro. My first choice of VM was VirtualBox, just cause I'm familiar with it a...
leak
Mar 31, 2011Aspirant
WhoCares? wrote: Try a different browser, that's a known problem of the jquery-version I'm forced to use in the add-on.
-Stefan
Tried both Firefox and Explorer, same thing. Is there any way I can doublecheck if vboxdrv really is running?
Edit; Looks like VB isnt running at all. And I dont get any error's when I run
t0wnz:~# /etc/init.d/vboxdrv start
Starting VirtualBox kernel module ...done.
t0wnz:~#
