chirpa
Mar 07, 2009Luminary
Running VirtualBox VM host on ReadyNAS Pro
What is VirtualBox? So, I got bored while laundry was going... and decided to see how well a virtual OS would run on the Pro. My first choice of VM was VirtualBox, just cause I'm familiar with it a...
WhoCares_
Mar 31, 2011Mentor
I fear using SSH would be the only way. And while you're on the command line you may also fix the config file for the problem with line breaks shouldn't show there.
-Stefan
-Stefan
