chirpa
Mar 07, 2009Luminary
Running VirtualBox VM host on ReadyNAS Pro
What is VirtualBox? So, I got bored while laundry was going... and decided to see how well a virtual OS would run on the Pro. My first choice of VM was VirtualBox, just cause I'm familiar with it a...
leak
Mar 31, 2011Aspirant
WhoCares? wrote: I fear using SSH would be the only way. And while you're on the command line you may also fix the config file for the problem with line breaks shouldn't show there.
-Stefan
Theres no problem using ssh for me. And for the config file in frontview folder (ssh) there are not any linebreaks at all.
Should I see the VB when I type "ps -A" lika a running proccess? How can I confirm that it actually working?
t0wnz:~# /etc/init.d/vboxdrv status
VirtualBox kernel modules (vboxdrv, vboxnetflt and vboxnetadp) are loaded.
It all looks good, but I cant find anything about vbox under "ps -A" at all.
