chirpa
Mar 07, 2009Luminary
Running VirtualBox VM host on ReadyNAS Pro
What is VirtualBox? So, I got bored while laundry was going... and decided to see how well a virtual OS would run on the Pro. My first choice of VM was VirtualBox, just cause I'm familiar with it a...
leak
Mar 31, 2011Aspirant
WhoCares? wrote: Can't say much about that right now, will have to check when I'm in the office again later at night today.
-Stefan
Thank you for taking time anyway. Really looking forward to getting this to work!
If it matter, I followed sphardy's guide (viewtopic.php?f=35&t=26468&start=225#p258406). But used the newest version (4.2.15) but the same VB version.
Edit; Made som headway! Installed the 4.0 instead, and now I get a config file for the phpscript. I have the vboxwebsrv running, but when i try to access nas-ip/phpboxmgr I get this message
SoapFault Object
[message:protected] => Method 'ns1:ISystemProperties_getMaxVDISize' not implemented: method name or namespace not recognized
[string:private] =>
[code:protected] => 0
[file:protected] => /frontview/ui/resource/html/phpvboxmgr/lib/vboxServiceWrappers.php
[line:protected] => 3592
[trace:private] => Array
[0] => Array
[file] => /frontview/ui/resource/html/phpvboxmgr/lib/vboxServiceWrappers.php
[line] => 3592
[function] => __soapCall
[class] => SoapClient
[type] => ->
[args] => Array
[0] => ISystemProperties_getMaxVDISize
[1] => Array
[0] => Array
[_this] => 2980c5227245087f-000000000000007e
[1] => Array
[line] => 54
[function] => getMaxVDISize
[class] => ISystemProperties
[type] => ->
[args] => Array
[2] => Array
[file] => /frontview/ui/resource/html/phpvboxmgr/lib/vboxconnector.php
[line] => 2631
[function] => __get
[class] => VBox_ManagedObject
[type] => ->
[args] => Array
[0] => maxVDISize
[3] => Array
[line] => 218
[function] => getSystemPropertiesCached
[class] => vboxconnector
[type] => ->
[args] => Array
[0] => Array
[fn] => getSystemProperties
[1] => Array
[data] =>
[errors] => Array
[persist] => Array
[4] => Array
[function] => __call
[type] => ->
[args] => Array
[0] => getSystemProperties
[1] => Array
[0] => Array
[1] => Array
[0] => Array
[data] =>
[errors] => Array
[persist] => Array
[5] => Array
[file] => /frontview/ui/resource/html/phpvboxmgr/lib/ajax.php
[line] => 93
[type] => ->
[args] => Array
[0] => Array
[1] => Array
[0] => Array
[data] =>
[errors] => Array
[persist] => Array
[faultstring] => Method 'ns1:ISystemProperties_getMaxVDISize' not implemented: method name or namespace not recognized
[faultcode] => SOAP-ENV:Sender
Edit2; Seems like phpvirtualbox isnt compatible with php5 at all. Altho they have released a new build, version 0.4-5.
Is anyone here running phpvirtualbox with vbox 4.x.x successfully?
Edit3; Installed phpvbox 0.4-5 instead and now it works flawless! I just swaped the config file with the old config file and it worked (probably missed some new feature tho).
