chirpa
Mar 07, 2009Luminary
Running VirtualBox VM host on ReadyNAS Pro
What is VirtualBox? So, I got bored while laundry was going... and decided to see how well a virtual OS would run on the Pro. My first choice of VM was VirtualBox, just cause I'm familiar with it a...
leak
Apr 06, 2011Aspirant
New radiator out now and I updated without thinking about VB, so now it's broken. Tried to download the new .16 GPL but failing at "make ARCH=x86_64".
So, is it possible to install VB on the new radiator, 4.2.16 ?
And also, how do I expand the capacity? I choose about 10gb, but after 3-4gb its full. And Should it really be stored at /dev/md0?
