chirpa
Mar 07, 2009Luminary
Running VirtualBox VM host on ReadyNAS Pro
What is VirtualBox? So, I got bored while laundry was going... and decided to see how well a virtual OS would run on the Pro. My first choice of VM was VirtualBox, just cause I'm familiar with it a...
jmalmlund
Apr 07, 2011Aspirant
leak wrote: And also, how do I expand the capacity? I choose about 10gb, but after 3-4gb its full. And Should it really be stored at /dev/md0?
/dev/md0 is system root which is 4GB and you should really NOT store ANYTHING on there unless absolutely necessary, which should be close to never.
Keep all your data on /dev/c/c,d,e,f.... and if you want to have something to appear to be on a system path use symlinks to the actual data.
