chirpa
Mar 07, 2009Luminary
Running VirtualBox VM host on ReadyNAS Pro
What is VirtualBox? So, I got bored while laundry was going... and decided to see how well a virtual OS would run on the Pro. My first choice of VM was VirtualBox, just cause I'm familiar with it a...
jmalmlund
Apr 07, 2011Aspirant
WhoCares? wrote:
jmalmlund wrote: Edit: It seems Netgear has made some mistake or I'm just tired... the new GPL source supplied contains kernel version 2.6.37.5.RNx86_64.2.2 but the kernel that's included in 4.2.16 is version 2.6.37.5.RNx86_64.2.1
I don't know how you come to that conclusion. The GPL sources I'm using contain a kernel that identifies itself as "2.6.37.5.RNx86_64.2.1" - as can be checked bycd linux-2.6.37.5/arch/x86/configs
grep "RNx86" *
Should list defconfig.smp with a CONFIG_LOCALVERSION string of ".RNx86_64.2.1"
Yes, it should, but my first download said ".2" in the end.. but then again, I downloaded the sources before the link and listed md5sum was posted.
Now after re-downloading and checking the md5sum this time around I get the correct md5sum so I'll start over now.
WhoCares? wrote:
jmalmlund wrote: Netgear have not only provided us with a GPL source that doesn't match the one they used to build the actual 4.2.16 release but they also have an incomplete kernel source lacking patches needed to compile!
Both drivers/target/target_core_iblock.c and drivers/target/target_core_pscsi.c and has references to an undecleard pointer, 'blkdev_get_by_path'
I just compiled the kernel for the fun of it. Those two files you name aren't built here at all so that has to be related to a problem with your kernel config. Also the kernel is built without problems for me.
I took the config file from 4.2.15 and started from that, I think they are or at least were needed for iSCSI target.
WhoCares? wrote:
jmalmlund wrote: I'm going to try and patch the source now but I fear I might break Frontview by replacing the firmware kernel by my own build.
No need to worry, you simply can't replace the kernel. The worst thing that'll happen is that your modules will fail to load.
jmalmlund wrote: So I think we're out of luck (to get VirtualBox back any easy way) until Netgear realizes their mistake and re-releases the GPL source they really did use when they built 4.2.16.
Well, I don't know who's to blame here and I'm not going to judge either. All I can say is that it works for me using the GPL source archive I downloaded. Which may be a different one than the one you downloaded but I don't know that either. I do know, however, that the md5sum of my GPL sources archive matches the MD5 given at the download page for 4.2.16 GPL sources.
-Stefan
Well, I'm to blame for posting to soon, cuz, a re-download of the source wasn't hard to do :? :oops:
