chirpa
Mar 07, 2009Luminary
Running VirtualBox VM host on ReadyNAS Pro
What is VirtualBox? So, I got bored while laundry was going... and decided to see how well a virtual OS would run on the Pro. My first choice of VM was VirtualBox, just cause I'm familiar with it a...
leak
Apr 08, 2011Aspirant
WhoCares? wrote: cd linux-2.6.37.5
make mrproper
cp arch/x86/configs/defconfig.smp .config
make ARCH=x86_64 silentoldconfig
-Stefan
Cant get my kernel module to start. vbox-install.log
Makefile:170: Warning: using /usr/src/linux as the source directory of your Linux kernel. If this is not correct, specify KERN_DIR=<directory> and run Make again.
make KBUILD_VERBOSE=1 SUBDIRS=/tmp/vbox.0 SRCROOT=/tmp/vbox.0 -C /usr/src/linux modules
test -e include/generated/autoconf.h -a -e include/config/auto.conf || ( \
echo; \
echo " ERROR: Kernel configuration is invalid."; \
echo " include/generated/autoconf.h or include/config/auto.conf are missing.";\
echo " Run 'make oldconfig && make prepare' on kernel src to fix it."; \
echo; \
/bin/false)
mkdir -p /tmp/vbox.0/.tmp_versions ; rm -f /tmp/vbox.0/.tmp_versions/*
WARNING: Symbol version dump /c/backup/GPL/linux-2.6.37.5/Module.symvers
is missing; modules will have no dependencies and modversions.
make -f scripts/Makefile.build obj=/tmp/vbox.0
/tmp/vbox.0/Makefile:170: Warning: using /usr/src/linux as the source directory of your Linux kernel. If this is not correct, specify KERN_DIR=<directory> and run Make again.
gcc -Wp,-MD,/tmp/vbox.0/linux/.SUPDrv-linux.o.d -nostdinc -isystem /usr/lib/gcc/i486-linux-gnu/4.1.2/include -I/c/backup/GPL/linux-2.6.37.5/arch/x86/include -Iinclude -include include/generated/autoconf.h -D__KERNEL__ -Wall -Wundef -Wstrict-prototypes -Wno-trigraphs -fno-strict-aliasing -fno-common -Werror-implicit-function-declaration -Wno-format-security -fno-delete-null-pointer-checks -O2 -m64 -mtune=generic -mno-red-zone -mcmodel=kernel -funit-at-a-time -maccumulate-outgoing-args -DCONFIG_AS_CFI=1 -DCONFIG_AS_CFI_SIGNAL_FRAME=1 -DCONFIG_AS_FXSAVEQ=1 -pipe -Wno-sign-compare -fno-asynchronous-unwind-tables -mno-sse -mno-mmx -mno-sse2 -mno-3dnow -fno-stack-protector -fno-omit-frame-pointer -fno-optimize-sibling-calls -g -Wdeclaration-after-statement -Wno-pointer-sign -I/usr/src/linux/include -I/tmp/vbox.0/ -I/tmp/vbox.0/include -I/tmp/vbox.0/r0drv/linux -I/tmp/vbox.0/vboxdrv/ -I/tmp/vbox.0/vboxdrv/include -I/tmp/vbox.0/vboxdrv/r0drv/linux -D__KERNEL__ -DMODULE -DRT_OS_LINUX -DIN_RING0 -DIN_RT_R0 -DIN_SUP_R0 -DVBOX -DRT_WITH_VBOX -DVBOX_WITH_HARDENING -DCONFIG_VBOXDRV_AS_MISC -DRT_ARCH_AMD64 -DVBOX_WITH_64_BITS_GUESTS -DMODULE -D"KBUILD_STR(s)=#s" -D"KBUILD_BASENAME=KBUILD_STR(SUPDrv_linux)" -D"KBUILD_MODNAME=KBUILD_STR(vboxdrv)" -c -o /tmp/vbox.0/linux/.tmp_SUPDrv-linux.o /tmp/vbox.0/linux/SUPDrv-linux.c
In file included from /tmp/vbox.0/linux/SUPDrv-linux.c:31:
/tmp/vbox.0/linux/../SUPDrvInternal.h:81:30: error: linux/version.h: No such file or directory
/tmp/vbox.0/linux/../SUPDrvInternal.h:84:12: warning: "LINUX_VERSION_CODE" is not defined
/tmp/vbox.0/linux/../SUPDrvInternal.h:84:33: warning: "KERNEL_VERSION" is not defined
/tmp/vbox.0/linux/../SUPDrvInternal.h:84:47: error: missing binary operator before token "("
/tmp/vbox.0/linux/../SUPDrvInternal.h:88:8: warning: "LINUX_VERSION_CODE" is not defined
/tmp/vbox.0/linux/../SUPDrvInternal.h:88:29: warning: "KERNEL_VERSION" is not defined
/tmp/vbox.0/linux/../SUPDrvInternal.h:88:43: error: missing binary operator before token "("
In file included from include/linux/gfp.h:4,
from include/linux/slab.h:12,
from /tmp/vbox.0/linux/../SUPDrvInternal.h:100,
include/linux/mmzone.h:18:30: error: generated/bounds.h: No such file or directory
include/linux/mmzone.h:254:5: warning: "MAX_NR_ZONES" is not defined
include/linux/mmzone.h:303: error: ‘MAX_NR_ZONES’ undeclared here (not in a function)
/tmp/vbox.0/linux/../SUPDrvInternal.h:101:8: warning: "LINUX_VERSION_CODE" is not defined
/tmp/vbox.0/linux/../SUPDrvInternal.h:101:30: warning: "KERNEL_VERSION" is not defined
/tmp/vbox.0/linux/../SUPDrvInternal.h:101:44: error: missing binary operator before token "("
/tmp/vbox.0/linux/../SUPDrvInternal.h:104:34: error: asm/semaphore.h: No such file or directory
In file included from /tmp/vbox.0/linux/SUPDrv-linux.c:32:
/tmp/vbox.0/r0drv/linux/the-linux-kernel.h:43:5: warning: "LINUX_VERSION_CODE" is not defined
/tmp/vbox.0/r0drv/linux/the-linux-kernel.h:43:26: warning: "KERNEL_VERSION" is not defined
/tmp/vbox.0/r0drv/linux/the-linux-kernel.h:43:40: error: missing binary operator before token "("
/tmp/vbox.0/r0drv/linux/the-linux-kernel.h:46:5: warning: "LINUX_VERSION_CODE" is not defined
/tmp/vbox.0/r0drv/linux/the-linux-kernel.h:46:27: warning: "KERNEL_VERSION" is not defined
/tmp/vbox.0/r0drv/linux/the-linux-kernel.h:46:41: error: missing binary operator before token "("
/tmp/vbox.0/r0drv/linux/the-linux-kernel.h:66:5: warning: "LINUX_VERSION_CODE" is not defined
/tmp/vbox.0/r0drv/linux/the-linux-kernel.h:66:27: warning: "KERNEL_VERSION" is not defined
/tmp/vbox.0/r0drv/linux/the-linux-kernel.h:66:41: error: missing binary operator before token "("
/tmp/vbox.0/r0drv/linux/the-linux-kernel.h:72:5: warning: "LINUX_VERSION_CODE" is not defined
/tmp/vbox.0/r0drv/linux/the-linux-kernel.h:72:27: warning: "KERNEL_VERSION" is not defined
/tmp/vbox.0/r0drv/linux/the-linux-kernel.h:72:41: error: missing binary operator before token "("
/tmp/vbox.0/r0drv/linux/the-linux-kernel.h:78:5: warning: "LINUX_VERSION_CODE" is not defined
/tmp/vbox.0/r0drv/linux/the-linux-kernel.h:78:27: warning: "KERNEL_VERSION" is not defined
/tmp/vbox.0/r0drv/linux/the-linux-kernel.h:78:41: error: missing binary operator before token "("
In file included from /tmp/vbox.0/r0drv/linux/the-linux-kernel.h:81,
include/linux/mm.h:466:63: warning: "NR_PAGEFLAGS" is not defined
include/linux/mm.h:514:62: warning: "NR_PAGEFLAGS" is not defined
/tmp/vbox.0/r0drv/linux/the-linux-kernel.h:86:5: warning: "LINUX_VERSION_CODE" is not defined
/tmp/vbox.0/r0drv/linux/the-linux-kernel.h:86:27: warning: "KERNEL_VERSION" is not defined
/tmp/vbox.0/r0drv/linux/the-linux-kernel.h:86:41: error: missing binary operator before token "("
/tmp/vbox.0/r0drv/linux/the-linux-kernel.h:89:5: warning: "LINUX_VERSION_CODE" is not defined
/tmp/vbox.0/r0drv/linux/the-linux-kernel.h:89:27: warning: "KERNEL_VERSION" is not defined
/tmp/vbox.0/r0drv/linux/the-linux-kernel.h:89:41: error: missing binary operator before token "("
/tmp/vbox.0/r0drv/linux/the-linux-kernel.h:94:5: warning: "LINUX_VERSION_CODE" is not defined
/tmp/vbox.0/r0drv/linux/the-linux-kernel.h:94:27: warning: "KERNEL_VERSION" is not defined
/tmp/vbox.0/r0drv/linux/the-linux-kernel.h:94:41: error: missing binary operator before token "("
/tmp/vbox.0/r0drv/linux/the-linux-kernel.h:117:5: warning: "LINUX_VERSION_CODE" is not defined
/tmp/vbox.0/r0drv/linux/the-linux-kernel.h:117:26: warning: "KERNEL_VERSION" is not defined
/tmp/vbox.0/r0drv/linux/the-linux-kernel.h:117:40: error: missing binary operator before token "("
/tmp/vbox.0/r0drv/linux/the-linux-kernel.h:130:5: warning: "LINUX_VERSION_CODE" is not defined
/tmp/vbox.0/r0drv/linux/the-linux-kernel.h:130:26: warning: "KERNEL_VERSION" is not defined
/tmp/vbox.0/r0drv/linux/the-linux-kernel.h:130:40: error: missing binary operator before token "("
/tmp/vbox.0/r0drv/linux/the-linux-kernel.h:171:5: warning: "LINUX_VERSION_CODE" is not defined
/tmp/vbox.0/r0drv/linux/the-linux-kernel.h:171:26: warning: "KERNEL_VERSION" is not defined
/tmp/vbox.0/r0drv/linux/the-linux-kernel.h:171:40: error: missing binary operator before token "("
/tmp/vbox.0/r0drv/linux/the-linux-kernel.h:205:7: warning: "LINUX_VERSION_CODE" is not defined
/tmp/vbox.0/r0drv/linux/the-linux-kernel.h:205:29: warning: "KERNEL_VERSION" is not defined
/tmp/vbox.0/r0drv/linux/the-linux-kernel.h:205:43: error: missing binary operator before token "("
/tmp/vbox.0/r0drv/linux/the-linux-kernel.h:207:7: warning: "LINUX_VERSION_CODE" is not defined
/tmp/vbox.0/r0drv/linux/the-linux-kernel.h:207:29: warning: "KERNEL_VERSION" is not defined
/tmp/vbox.0/r0drv/linux/the-linux-kernel.h:207:43: error: missing binary operator before token "("
/tmp/vbox.0/r0drv/linux/the-linux-kernel.h:225:6: warning: "LINUX_VERSION_CODE" is not defined
/tmp/vbox.0/r0drv/linux/the-linux-kernel.h:225:27: warning: "KERNEL_VERSION" is not defined
/tmp/vbox.0/r0drv/linux/the-linux-kernel.h:225:41: error: missing binary operator before token "("
/tmp/vbox.0/r0drv/linux/the-linux-kernel.h:232:6: warning: "LINUX_VERSION_CODE" is not defined
/tmp/vbox.0/r0drv/linux/the-linux-kernel.h:232:27: warning: "KERNEL_VERSION" is not defined
/tmp/vbox.0/r0drv/linux/the-linux-kernel.h:232:41: error: missing binary operator before token "("
/tmp/vbox.0/r0drv/linux/the-linux-kernel.h:270:5: warning: "LINUX_VERSION_CODE" is not defined
/tmp/vbox.0/r0drv/linux/the-linux-kernel.h:270:27: warning: "KERNEL_VERSION" is not defined
/tmp/vbox.0/r0drv/linux/the-linux-kernel.h:270:41: error: missing binary operator before token "("
/tmp/vbox.0/r0drv/linux/the-linux-kernel.h:358:5: warning: "LINUX_VERSION_CODE" is not defined
/tmp/vbox.0/r0drv/linux/the-linux-kernel.h:358:27: warning: "KERNEL_VERSION" is not defined
/tmp/vbox.0/r0drv/linux/the-linux-kernel.h:358:41: error: missing binary operator before token "("
/tmp/vbox.0/linux/SUPDrv-linux.c:47:5: warning: "LINUX_VERSION_CODE" is not defined
/tmp/vbox.0/linux/SUPDrv-linux.c:47:27: warning: "KERNEL_VERSION" is not defined
/tmp/vbox.0/linux/SUPDrv-linux.c:47:41: error: missing binary operator before token "("
/tmp/vbox.0/linux/SUPDrv-linux.c:69:7: warning: "LINUX_VERSION_CODE" is not defined
/tmp/vbox.0/linux/SUPDrv-linux.c:69:28: warning: "KERNEL_VERSION" is not defined
/tmp/vbox.0/linux/SUPDrv-linux.c:69:42: error: missing binary operator before token "("
/tmp/vbox.0/linux/SUPDrv-linux.c:172:6: warning: "LINUX_VERSION_CODE" is not defined
/tmp/vbox.0/linux/SUPDrv-linux.c:172:28: warning: "KERNEL_VERSION" is not defined
/tmp/vbox.0/linux/SUPDrv-linux.c:172:42: error: missing binary operator before token "("
/tmp/vbox.0/linux/SUPDrv-linux.c:220:5: warning: "LINUX_VERSION_CODE" is not defined
/tmp/vbox.0/linux/SUPDrv-linux.c:220:27: warning: "KERNEL_VERSION" is not defined
/tmp/vbox.0/linux/SUPDrv-linux.c:220:41: error: missing binary operator before token "("
/tmp/vbox.0/linux/SUPDrv-linux.c: In function ‘vboxdrvLinuxUid’:
/tmp/vbox.0/linux/SUPDrv-linux.c:223: error: ‘struct task_struct’ has no member named ‘uid’
/tmp/vbox.0/linux/SUPDrv-linux.c:229:5: warning: "LINUX_VERSION_CODE" is not defined
/tmp/vbox.0/linux/SUPDrv-linux.c:229:27: warning: "KERNEL_VERSION" is not defined
/tmp/vbox.0/linux/SUPDrv-linux.c:229:41: error: missing binary operator before token "("
/tmp/vbox.0/linux/SUPDrv-linux.c: In function ‘vboxdrvLinuxGid’:
/tmp/vbox.0/linux/SUPDrv-linux.c:232: error: ‘struct task_struct’ has no member named ‘gid’
/tmp/vbox.0/linux/SUPDrv-linux.c:238:5: warning: "LINUX_VERSION_CODE" is not defined
/tmp/vbox.0/linux/SUPDrv-linux.c:238:27: warning: "KERNEL_VERSION" is not defined
/tmp/vbox.0/linux/SUPDrv-linux.c:238:41: error: missing binary operator before token "("
/tmp/vbox.0/linux/SUPDrv-linux.c: In function ‘vboxdrvLinuxEuid’:
/tmp/vbox.0/linux/SUPDrv-linux.c:241: error: ‘struct task_struct’ has no member named ‘euid’
make[2]: *** [/tmp/vbox.0/linux/SUPDrv-linux.o] Error 1
make[1]: *** [_module_/tmp/vbox.0] Error 2
make: *** [vboxdrv] Error 2
Any tips?
