chirpa
Mar 07, 2009Luminary
Running VirtualBox VM host on ReadyNAS Pro
What is VirtualBox? So, I got bored while laundry was going... and decided to see how well a virtual OS would run on the Pro. My first choice of VM was VirtualBox, just cause I'm familiar with it a...
leak
Apr 08, 2011Aspirant
WhoCares? wrote: Without further information: Not really ;) Did you run at least "make modules_prepare" in your kernel directory?
-Stefan
Did one, but almost the same problem.. This time vboxdrv setup took some longer time, but it failed anyway..
If I remove everything and re-install it, can I follow the guide a couple pages back but change to the new version? And copy the file like you posted?
