chirpa
Mar 07, 2009Luminary
Running VirtualBox VM host on ReadyNAS Pro
What is VirtualBox? So, I got bored while laundry was going... and decided to see how well a virtual OS would run on the Pro. My first choice of VM was VirtualBox, just cause I'm familiar with it a...
leak
Apr 11, 2011Aspirant
Sebastien wrote: Hello,
Progress state: NS_ERROR_FAILURE
VBoxManage: error: Failed to install "/root/Oracle_VM_VirtualBox_Extension_Pack-4.0.4-70112.vbox-extpack": Extension pack 'Oracle VM VirtualBox Extension Pack' is already installed. In case of a reinstallation, please uninstall it first
ChildNemesis:~# /etc/init.d/vboxdrv setup
Stopping VirtualBox kernel modules ...done.
Uninstalling old VirtualBox DKMS kernel modules ...done.
Trying to register the VirtualBox kernel modules using DKMS ...failed!
(Failed, trying without DKMS)
Recompiling VirtualBox kernel modules ...failed!
(Look at /var/log/vbox-install.log to find out what went wrong)
Would you have an idea of what to do?
Havin the same problem. vbox-install.log
t0wnz:~# cat /var/log/vbox-install.log
Makefile:167: *** Error: unable to find the sources of your current Linux kernel. Specify KERN_DIR=<directory> and run Make again. Stop.
