chirpa
Mar 07, 2009Luminary
Running VirtualBox VM host on ReadyNAS Pro
What is VirtualBox? So, I got bored while laundry was going... and decided to see how well a virtual OS would run on the Pro. My first choice of VM was VirtualBox, just cause I'm familiar with it a...
leak
Apr 12, 2011Aspirant
Sebastien wrote: Ok, so for me the solution was:
ChildNemesis:~# cd /usr/src/linux/
ChildNemesis:/usr/src/linux# make
ChildNemesis:~# ./VirtualBox-4.0.4-70112-Linux_amd64.run
ChildNemesis:~# /etc/init.d/vboxdrv start
A very big thank you to jmalmlund.
argh! Did almost this before, just forgot to run vb-4.0.4!
Works great now tho, so thanks!
