chirpa
Mar 07, 2009Luminary
Running VirtualBox VM host on ReadyNAS Pro
What is VirtualBox? So, I got bored while laundry was going... and decided to see how well a virtual OS would run on the Pro. My first choice of VM was VirtualBox, just cause I'm familiar with it a...
jmalmlund
May 08, 2011Aspirant
TeknoJnky wrote: tried the updated guide, frodo:/c/.vbox# /etc/init.d/vboxdrv setup
Stopping VirtualBox kernel modules ...done.
Uninstalling old VirtualBox DKMS kernel modules ...done.
Removing old VirtualBox netadp kernel module ...done.
Removing old VirtualBox netflt kernel module ...done.
Removing old VirtualBox kernel module ...done.
Trying to register the VirtualBox kernel modules using DKMS ...failed!
(Failed, trying without DKMS)
Recompiling VirtualBox kernel modules ...done.
Starting VirtualBox kernel modules ...failed!
(modprobe vboxdrv failed. Please use 'dmesg' to find out why)
dmsg:vboxdrv: no symbol version for module_layout
What's your status on this now? Have you worked it out?
If not, could you help me help you, please give some more details on your system, what model NAS do you have, what RAIDiator version is it running and so on.
Also check your kernel source directory, does the file "Module.symvers" exist? The dmsg output that you included is known to happen if that file's not found.
