chirpa
Mar 07, 2009Luminary
Running VirtualBox VM host on ReadyNAS Pro
What is VirtualBox? So, I got bored while laundry was going... and decided to see how well a virtual OS would run on the Pro. My first choice of VM was VirtualBox, just cause I'm familiar with it a...
mdgm-ntgr
May 14, 2011NETGEAR Employee Retired
Sounds like you want to try http://www.readynas.com/forum/viewtopic.php?f=48&t=44145
Search the forum for tips on how best to use it.
