chirpa
Mar 07, 2009Luminary
Running VirtualBox VM host on ReadyNAS Pro
What is VirtualBox? So, I got bored while laundry was going... and decided to see how well a virtual OS would run on the Pro. My first choice of VM was VirtualBox, just cause I'm familiar with it a...
Gurutek
May 14, 2011Aspirant
OK - I think I have Virtualbox successfully installed and running..
I'm trying to get PHPVirtualbox running so I can manage the VM environment. I've searched the forum but cannot find the answer to these two questions:
The addon requires that you have one vm running - Catch 22 here, as I was going to use phpvboxmgr to create one..... Is CLi the only option?
What does verifying the config do? What should it look like? Mine looks like this:
86400, // "never" changes 'getGuestOSTypes' => 86400, 'getSystemProperties' => 86400, 'getInternalNetworks' => 86400, 'getMediums' => 600, 'getVMs' => 2, '__getMachine' => 7200, '__getNetworkAdapters' => 7200, '__getStorageControllers' => 7200, '__getSharedFolders' => 7200, '__getUSBController' => 7200, ); */ }
Is that right?
Thanks for the help!!!!
Is that right?
