chirpa
Mar 07, 2009Luminary
Running VirtualBox VM host on ReadyNAS Pro
What is VirtualBox? So, I got bored while laundry was going... and decided to see how well a virtual OS would run on the Pro. My first choice of VM was VirtualBox, just cause I'm familiar with it a...
mdgm-ntgr
May 14, 2011NETGEAR Employee Retired
I haven't used VirtualBox on the ReadyNAS, but I think you'd need to create your first VM using the CLI (thereafter you should hopefully be able to use the GUI). As for getting VirtualBox to automatically start on each boot, I think there's instructions somewhere (maybe in this thread).
