chirpa
Mar 07, 2009Luminary
Running VirtualBox VM host on ReadyNAS Pro
What is VirtualBox? So, I got bored while laundry was going... and decided to see how well a virtual OS would run on the Pro. My first choice of VM was VirtualBox, just cause I'm familiar with it a...
mdgm-ntgr
Jun 14, 2011NETGEAR Employee Retired
I would try the amd64 version then. Not sure why that needs to be used (I haven't installed VirtualBox personally). Hopefully someone can explain.
