chirpa
Mar 07, 2009Luminary
Running VirtualBox VM host on ReadyNAS Pro
What is VirtualBox? So, I got bored while laundry was going... and decided to see how well a virtual OS would run on the Pro. My first choice of VM was VirtualBox, just cause I'm familiar with it a...
troypiggo1
Jun 23, 2011Tutor
I should have mentioned that I solved the previous issue. I realised I was extracting onto a small partition and filling it up. I changed to /c/VirtualBox and the whole GPL did extract fine.
So the problem must be something else?
