chirpa
Mar 07, 2009Luminary
Running VirtualBox VM host on ReadyNAS Pro
What is VirtualBox? So, I got bored while laundry was going... and decided to see how well a virtual OS would run on the Pro. My first choice of VM was VirtualBox, just cause I'm familiar with it a...
jmalmlund
Jun 25, 2011Aspirant
troypiggo wrote: I should have mentioned that I solved the previous issue. I realised I was extracting onto a small partition and filling it up. I changed to /c/VirtualBox and the whole GPL did extract fine.
So the problem must be something else?
No, not necceseryly...
# VBoxManage setproperty machinefolder "`pwd`"
You set the machinefolder to your current directory when you issued the above command.
The "pwd" command is a short for "print working directory" so if you were in the root-home dir when gave the commands setting up your vm the you're storing the disk-image on the small sys-partition.
