chirpa
Mar 07, 2009Luminary
Running VirtualBox VM host on ReadyNAS Pro
What is VirtualBox? So, I got bored while laundry was going... and decided to see how well a virtual OS would run on the Pro. My first choice of VM was VirtualBox, just cause I'm familiar with it a...
troypiggo1
Jun 25, 2011Tutor
Thanks guys. Can't access the machine until Monday, so can't post output to show you. Pretty sure `pwd` was /c/VirtualBox - I know what the command means and was just being lazy. But would like to check in case I did something silly. I usually do type full paths for safety.
