chirpa
Mar 07, 2009Luminary
Running VirtualBox VM host on ReadyNAS Pro
What is VirtualBox? So, I got bored while laundry was going... and decided to see how well a virtual OS would run on the Pro. My first choice of VM was VirtualBox, just cause I'm familiar with it a...
jmalmlund
Sep 09, 2011Aspirant
Just a word of waring, DON'T update to RAIDiator 4.2.19 yet! The apt-get repository isn't up-to-date and running 'apt-get -f install' will actually remove the some packages required to build the needed VirtualBox kernel modules.
