chirpa
Mar 07, 2009Luminary
Running VirtualBox VM host on ReadyNAS Pro
What is VirtualBox? So, I got bored while laundry was going... and decided to see how well a virtual OS would run on the Pro. My first choice of VM was VirtualBox, just cause I'm familiar with it a...
jmalmlund
Sep 18, 2011Aspirant
JeIlMa wrote:
jmalmlund wrote: Just a word of waring, DON'T update to RAIDiator 4.2.19 yet! The apt-get repository isn't up-to-date and running 'apt-get -f install' will actually remove the some packages required to build the needed VirtualBox kernel modules.
Forget to remove autoupdate... So RAIDiator has been upgrade to 4.2.19. Is there some steps that I can make to get this back to business?
-JeIlMa
I downgraded to 4.2.17 since that has worked good for me and it still does I might add. Also I still haven't upgraded my computers to Lion so I don't really really need any of the new features in 4.2.19 right now.
