chirpa
Mar 07, 2009Luminary
Running VirtualBox VM host on ReadyNAS Pro
What is VirtualBox? So, I got bored while laundry was going... and decided to see how well a virtual OS would run on the Pro. My first choice of VM was VirtualBox, just cause I'm familiar with it a...
jmalmlund
Dec 12, 2011Aspirant
laksmkk wrote: With the mini-guide written by jmalmlund was successfully able to install Windows. Now here is my question? How do I install the sound card?
First you need to assign what soundcard your virtual machine should have, for a Windows XP machine this would do.
VBoxManage modifyvm <name> --audiocontroller ac97
If you use Vista 64bit or Windows 7 32/64bit the only supported controller (soundcard) is named "hda"..
Once this is done (with machine powered off) and you start it again you just need to install the appropriate windows drivers to support the card you selected to use.
ps. When setting up your virtual machines from a console everything is done using the application 'VBoxManage' and to get usage help just type 'VBoxManage' without any commands and it'll print a list of all supported commands. If you just need a reminder of how 'VBoxManage modifyvm' works, then press enter after that and you'll get help on just 'modifyvm' section.
