chirpa
Mar 07, 2009Luminary
Running VirtualBox VM host on ReadyNAS Pro
What is VirtualBox? So, I got bored while laundry was going... and decided to see how well a virtual OS would run on the Pro. My first choice of VM was VirtualBox, just cause I'm familiar with it a...
maciekish
Jan 18, 2012Aspirant
jmalmlund wrote:
InTheShires wrote:
MikeMcr wrote:
jmalmlund wrote: Only problem is that the software-repository holding these components for 4.2.19 is broken with version mismatches and creating an add-on that first downgrades the installed RAIDiator software to 4.2.17, a version that to my knowledge doesn't work well with Mac OS X Lion afp isn't a good idea.
Has this been fixed yet? Am I safe to install VirtualBox with 4.2.19?
I don't know the answer at all, but I'm running into errors that "could" relate the above quote. (At least the way I'm interpreting things)
I'm simply trying to install bzip2/bunzip2.
4.2.19 is still a no-go and I don't expect it to ever get fixed eigther seeing how work on 4.2.20 seems to be progressing with numerous beta releases already. I just hope that Netgear doesn't make the same mistake again and that we'll have a working software repository once again when 4.2.20 is released in finalized form.
Its not a no-go. I got it running and i just installed bzip2 from sources on http://bzip.org/.
Just make && make install. No ./configure
