chirpa
Mar 07, 2009Luminary
Running VirtualBox VM host on ReadyNAS Pro
What is VirtualBox? So, I got bored while laundry was going... and decided to see how well a virtual OS would run on the Pro. My first choice of VM was VirtualBox, just cause I'm familiar with it a...
cduce
Feb 15, 2012Aspirant
Ok, so during my numerous attempts to install VirtualBox on my Ultra+, here's where I stand and I need some assistance from the community.
- Before going on this Journey, my FW was at 4.2.19, and I ran into quite a few issues attempting to get VB installed; so I saw a few posts where ppl were having success with FW 4.2.17, so I figured a downgrade wouldn't hurt.
- I proceed with the downgrade and now I cannot access my NAS via GUI, but can still access via SSH., Not exactly sure what I may have done to the GUI, but I need to get it back.
- Also, everytime I try to do an apt-get -f install, I get the following error msg:
Linking and byte-compiling packages for runtime python2.4...
Traceback (most recent call last):
File "/usr/lib/python2.4/py_compile.py", line 164, in ?
main()
File "/usr/lib/python2.4/py_compile.py", line 159, in main
compile(filename, doraise=True)
File "/usr/lib/python2.4/py_compile.py", line 115, in compile
f = open(file, 'U')
IOError: [Errno 2] No such file or directory: '-'
dpkg: error processing python2.4-minimal (--configure):
subprocess post-installation script returned error exit status 1
dpkg: dependency problems prevent configuration of python2.4:
python2.4 depends on python2.4-minimal (= 2.4.4-3+etch3); however:
Package python2.4-minimal is not configured yet.
dpkg: error processing python2.4 (--configure):
dependency problems - leaving unconfigured
dpkg: dependency problems prevent configuration of virtualbox-2.1:
virtualbox-2.1 depends on python2.4 (>= 2.3.90); however:
Package python2.4 is not configured yet.
dpkg: error processing virtualbox-2.1 (--configure):
Setting up bzip2 (1.0.3-6) ...
Errors were encountered while processing:
python2.4-minimal
python2.4
virtualbox-2.1
E: Sub-process /usr/bin/dpkg returned an error code (1)
Any guidance on this will be appreciated :)
main()
f = open(file, 'U')
python2.4-minimal
python2.4
virtualbox-2.1
